Gentlemen
What is the fastest and easiest way of creating below irregular type of concrete shear wall in Revit
Thanks in advance
Solved by ennujozlagam. Go to Solution.
Solved by A_MAQ. Go to Solution.
Solved by ToanDN. Go to Solution.
the lower section should not be modeled as wall it should be footing if it's in foundation level or slab if it's part of slab in upper level
so the above to section can be modeled as @ToanDN said even by in place family or stack wall
@revit1980 hello, here is the screencast, another approach on how to create Shear wall. thanks
Thank you Mr Junne Magalzo
both screencast deserves the kudo.
Warm regards,
