Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Shear Connection between two channels
14 REPLIES 14
Message 1 of 15
advandes
3568 Views, 14 Replies
Using Revit 2019
Does anyone know why I am getting errors trying to make a simple shear plate connection between two channels? See attached. These connections need to be coped and bolted with shear tabs. Pretty standard stuff.. Thanks for any help.
AAG
Advance Design
14 REPLIES 14
Message 2 of 15
mihai.sandu
in reply to: advandes
When a steel connection is placed on a steel profile a fabrication shape is created, based on the steel profile from Revit. This fabrication shape can't be created in some cases. I believe that the fabrication shape is not created in your case because the medium and fine levels of detail, of the Revit native steel beam, are not "consistent".
Please see below information from Help Document.
"The shapes of connected elements for medium and fine detail levels must be consistent. Straight segments defined in medium detail level should overlap segments defined in fine detail level. If the shape for the medium detail level is not the same as for the fine detail level, the steel fabrication shape will not be created and you will be notified by a warning message."
Here is  a link from the Revit Help Documentation which contains the Supported Structural Steel Shapes:
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Mihai Sandu
Sr. QA Analyst
Message 3 of 15
advandes
in reply to: mihai.sandu
Thank you for your response. I am accepting your solution to the issue as a link to Autodesks documentation, but it appears there is no solution. Very disappointing...
AAG
Advance Design
Message 4 of 15
andres_urrutia
did you créate that shape? you must clssify the member as a C-Shape…..
Message 5 of 15
advandes
in reply to: andres_urrutia
No, that is a standard channel from the framing library
AAG
Advance Design
Message 6 of 15
Aaron485
Was you ever able to get two channels to connect with a shear tab?  I have tried several things and still haven't found a way.
Message 7 of 15
advandes
in reply to: Aaron485
No, I now use Advance Steel 2020 for projects that require detailed connections, and then import the file into Revit.
AAG
Advance Design
Message 8 of 15
andres_urrutia
how do you import the AS file into Revit? as a xmls file or as a dwg file?
Message 9 of 15
advandes
I have done it both way, but I usually export .smlx format from Advance Steel. The process isn't always perfect, but it seems to get the job done when I have to do it this way. Advance Steel is a bear to learn, but once you do, it's much easier to model steel than with Revit. The screen capture I have attached is a simple structural frame I am working on that I imported into Revit.
AAG
Advance Design
Message 10 of 15
Aaron485
I did get my channel to beam connection to work in Revit 2019, I just had to change the beams to be the family from the AISC 14.1 folder, then they connected right up.
Message 11 of 15
meilechTPVL4
Still an issue in revit 2024.
Shear connection from "C-Channel Family" to a column. The Fine and Medium profiles don't overlap the way they should for revit to recognize the shape
per https://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
 This is frustrating considering its an out of the box autodesk family.
can confirm @Aaron485 solution works but the shape is slightly different. It can be a workaround, but if you are calculating poundage based on the Area X Mass (volumeXdensity) which I do, it will throw off the numbers slightly.
It just depends what you are trying to do.
Message 12 of 15
meilechTPVL4
in reply to: meilechTPVL4
To make my point
the top beam is the AISC 14.1  shape
the bottom beam is the Deafult family.
Both are the exact same length
Message 13 of 15
jasonmccool8686
Well, I guess I can see why Revit doesn't know what to do with channel connections when the default out-of-the-box channel family comes in malformed like this... Good grief, Autodesk.
Message 14 of 15
OK, apparently, it's not like that out of the box. Replacing the family when there was already a connection applied to the instance apparently caused the sloped surface of the flanges to flip like that. Deleting that whole channel and getting it back to an intact shape and then applying a cope to the members made the same thing happen again. Either way, really annoying. Does anyone know of a way to edit the family so it stops doing this, or is it a Steel Connections plugin error that corrupting the family?
Message 15 of 15
BVillarreal1126
I believe the Error lives deep within the parameters of the Profile not following in line with each other's shape.
Fine level - TF in conflictFine level - TF in conflictMed Level - TF in conflictMed Level - TF in conflict
If you compare that to the MC family those profiles are correct.....
Someone at the Main office (AutoDesk/IMF/Mystery tech guy) must of overlooked this
