Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Seemingly random lines in family showing up
6 REPLIES 6
386 Views, 6 Replies
Hiya,
I've been modelling a bench and there are some weird lines showing up (image attached). Which sometimes appear when the angle changed while making an extrusion and sometimes they just don't show up at all?
Is there a way to get rid of these?
Tags (4)
6 REPLIES 6
jay_colcombe
in reply to: 1007426
I think it depends of the extent of the angle but any change in plane should show a physical line to denote an edge you could try and smooth this out with a curve or you can always use the Linework Tool > Invisible
Jay Colcombe
Autodesk Certified Instructor
in reply to: jay_colcombe
Hiya
The linework tool is not showing up for me,
How do I get it to appear?
jay_colcombe
This is done in the Revit Model not the Family.
Jay Colcombe
Aha, is it not possible to hide these in the family then? Trying to keep everything as families so it's easy to import into Navisworks or Synchro.
jay_colcombe
No unfortunately, hence the suggestion of a smoothing option with a curse rather than an angle bend.
Jay Colcombe
Thanks for your help 🙂
Forma Design Contest
