Section View
Section View
muhtsaqif20
Section View
muhtsaqif20
Does anyone know how to make A section like that in revit?
alan.johnson7YLND
I think you would have to create two section views and manually crop and join them on a sheet.
One section would be horizontal and one would be at the angle.
muhtsaqif20
Thank you for your answer
ahmadaldo
Additionally, Autodesk Support states that "Revit does not support section views where the angle varies within the plane of the section line" which can be found through this link:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-cre...
However, you can see current discussion related to your question here:
https://forums.autodesk.com/t5/revit-ideas/segment-section-lines-which-are-not-perpendicular/idi-p/7...
Then, if you can run Dynamo, I guess this post will be helpful to be followed:
https://forum.dynamobim.com/t/creating-curved-cross-section-bridge-engineering/7710/17
You can mark this as a solution if it helps 🙂
