I have used AutoCAD for a number of years and have just started to look at Revit. I have been working though "Getting Started with Revit Architecture" and have just got to the section on creating sheets, all seems to work ok but I cannot see how you would place a view onto a sheet if you wanted it to fill the available space (just as scale to fit will work inside a viewport in AutoCAD) also is there a way to size a view, in the same way that you can zoom in or out inside a viewport in AutoCAD
Thanks William
