Roof is not visible in the Analytical view
Message 1 of 8
I created a roof by the "Metric Structural Framing - Complex and Trusses" family template in the Revit.  Later, I tried to place it on the top of the building. I enabled the visibility options for the analytical view. Even though, it is not showing the analytical view for the roof in the Revit Analytical model. To be clear, the roof members are created by the extrusion option. So, can anyone suggest to me how to get an analytical view of the roof structure? The figures are listed below.
Replies (7)
Message 2 of 8
elzohry2007
roof has no Analytical Model
use Floor (Enable Structural )
do not use Modify sub Element because it's Staight in AM
use 2 Floor with Solpe arrow to do what yo need
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Hosam Elzohry , ACI , ACP, Autodesk Ambassador Gold
BIM Manager
https://www.youracclaim.com/users/hosam-elzohry/badges
Message 3 of 8
elzohry2007
BIM Manager
Message 4 of 8
Thanks for suggesting the possible solutions. But, I need typically analytical members for that roof structural elements. I am want to do analysis in the other software. If I create as per your suggestion, that won't be possible for analysis.
Message 5 of 8
elzohry2007
roof Has no Analytical mode like Stairs  in revit
so you can not use it
Roof and Floor are mostly the Same
even if you draw it in any Analysis software  when it's come to revit it will be floor
Message 6 of 8
elzohry2007
thanks alot for accept it
Message 7 of 8
Hi
I tried to model my roof as a structural floor because I want to view the analytical model of my roof.
But The analytical model of the roof is not inclined but it is straight ahead as you can see in the photos.
How I can resolve it? Thank you so much
st
Message 8 of 8
These photos are more clear:
