Revit Rebar display
Revit Rebar display
jamarvinciemediano
Revit Rebar display
jamarvinciemediano
Does anyone know how to do this on Revit (1st image), I already tried my best but still didn't get same result (2nd image). I want to hide the bars in the footing underneath the column (3rd image)
jay_colcombe
You cannot use a Masking Region as it will cover everything in the View, and you don't want to be drawing detail lines!!!!
Therefore if we look at using the column as a the Mask!
Edit the View Visibility State settings of the Rebar in the Column to show in 3D via the Properties Palette
(Do not use this for the rebar in the foundation we need it Hidden)
Then use the Column to Mask the Rebar below in the Foundation and edit the transparency in the Foundation to show the rebar by selecting the Foundation > Right Click > Override Graphics in View > By Element
Jay Colcombe
Autodesk Certified Instructor
jamarvinciemediano
Thank you! It works, however I lost the concrete pattern in my foundation, do you have any idea how to make it visible. Thanks again
