Revit LT export to ifc empty!
Message 1 of 9
I'm having trouble exporting an IFC file from my Revit LT 2019 model. Whenever I try to export the ifc file is always empty (about 6KB). I've had a look in the help files and forums and think it might be to do with the mapping file, but I'm not sure what. Please can anyone help?
Thanks in advance!
Emma
Replies (8)
Message 2 of 9
MostafaElashmawy
Can you share the file?
Mostafa Elashmawy
Message 3 of 9
Tom_Kunsman
Are you even allowed to export to IFC in Revit LT?
Message 4 of 9
Here is the file.
Message 5 of 9
MostafaElashmawy
The file exported correctly at my side.
below are my settings and attached the exported file.
Mostafa Elashmawy
Message 6 of 9
Thanks for trying the export from your side. I have checked and my settings are the same as yours, but I still can't export it myself. Are there any other setting I should be checking?
Message 7 of 9
MostafaElashmawy
Yes. Check th IFC options and make sure to load the default file exportlayers-ifc-IAI.txt (attached)
Mostafa Elashmawy
Message 8 of 9
Thanks, but I have already done that after my search of the help files!
Message 9 of 9
pendean
Community Legend
Community Legend
I no longer run REVITLT2019, but I am able to export your file (with errors) from RevitLT2020
