Putting a filled region on a "layer" so it can be turned off in PDF
When you create a PDF from a CAD file, it retains the layer information so that you can turn certain layers off in the PDF.
Is there a way to use the same feature when you print PDFs from a Revit model? I want to put a hatch/filled region on a "layer" so that it can easily be turned off and on by the end user of the PDF.
MostafaElashmawy
The only way is to export to CAD first then print from CAD.
Mostafa Elashmawy
What I ended up doing is creating just the hatch in CAD, creating a PDF from that, and then doing "Add layer from page" in Bluebeam to the sheet I want the hatch to show up on. That way, the only item on a layer is the hatch created in CAD. Kind of a tedious workaround but it seems to do what I want it to do.
