Revit Extensions for 2017 version?
Priitl220
Message 1 of 63
Priitl220
Is there going to be Revit Extensions for 2017 version?
At least I could not find it.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Replies (62)
Message 2 of 63
L.Maas
They have been made available through the Autodesk Desktop App.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 63
Priitl220
I only see Revit extensions for Autodesk Fabrication 2017
This is not it.
In Revit2016
Message 4 of 63
L.Maas
I know...Revit 2017 Extensions
Louis
Message 5 of 63
floreai
You may try also on the website: https://accounts.autodesk.com
Please see the attached pic.
Best regards
Message 6 of 63
i can't found
Message 7 of 63
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 8 of 63
GFaustin
i have looked and checked and i cant get it  "Autodesk Revit Extensions 2017" I tried of looking...
Message 9 of 63
MurrayEkong
I too have tried and cant find the Revit 2017 extension, can an Autodesk employee help the forum out on this? There has been several reports by several users about this problem. It will be helpful if the direct links can be sent of the downloaded zipped file is attached to the responses. I do not intend to give up until this is resolved.
Murray
Message 10 of 63
MurrayEkong
The image below proves that the extension does not exist
Murray
Message 11 of 63
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check Private Message
Rafal Gaweda
Message 12 of 63
Hellow! Have you get the "Autodesk Revit Extensions 2017"? I'm tired to surching it, I kill 2 hours on this and nothing 😕
Can you give me a link on it or send exe-file on my e-mail?
Thanks.
Message 13 of 63
Dear defighte,
I also had the same problem.
Finally I found it in my autodesk account beneath updates & add ons.
You have to go to products and services.
In that menu you see your installments.
Right from the header - MORE
You see updates & add ons.
Click on that and you will find in that list the extension revit 2017.
Hopely you find it.
Kind regards,
A.J.
Message 14 of 63
Can someone send me the link for structural conexions?
Message 15 of 63
floreai
You can find the "Steel Connections for Revit" add-on by accessing Autodesk Desktop App, under the Revit tab, please see DesktopApp pic.
Or, by logging in to your account on https://accounts.autodesk.com, please see Accounts pic.
I hope this is what you are looking for.
Best regards,
Irina
Message 16 of 63
fernydja
The Revit Extensions for Autodesk Revit 2017 is no longer in the list of updates. Only 11 updates are there now and the Extensions for Autodesk Revit 2017 in not one of them. Was released on May 25, 2016 but seems to have been removed. Not sure why..... Autodesk please HELP!!
Message 17 of 63
GHASEM_ARIYANI
Hi @Rafal.Gaweda
There is no the list of my account Revit Extensions for 2017.
Thank you
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Message 18 of 63
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 19 of 63
GHASEM_ARIYANI
hi @Rafal.Gaweda
Thank you so much for your guide
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 20 of 63
hi please how can i download this
