Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Creating an Array in a Family
1 REPLY 1
628 Views, 1 Reply
HI! I am trying to create an array parameter that will allow me to change the number of studs coming out of a rail and adjust the spacing between them. I am new to Revit, so I don't know where to even start trying to make an array parameter. The stud is actually 2 pieces. The shaft is an extrusion and the the stud head is a blend sweep if that makes any difference. I have attached a word doc with screenshots of different views of my stud rail and the parameters I have already created to adjust the stud itself. Any help would be greatly appreciated. Thank you!!
1 REPLY 1
PrathapSekar
Hi!!!
   In below attached link you can learn how to create array and adjust the distance of elements parametrically. Al d bst.
                   Link: https://www.youtube.com/watch?v=Q5MyzijIuco
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Forma Design Contest
