I’m trying to reach out to Autodesk to inquire as to whether or not the “Revit Extensions” for reinforcing have been discontinued. Is there someone on the structure end of the product that may be able to answer this question and what the alternate approach may be. We at our firm have found the extensions extremely used for generating rebar in host elements such as footing and columns and am hoping they will be released for RST2019.
Solved by jason.colcombe. Go to Solution.
Solved by MichaelWSullivan. Go to Solution.
Have you looked at Precast addin for Revit 2019, can be found in Autodesk account, manage.autodesk.com
we currently do not have an ETA as to when the add-ins Revit Extensions will be released for our 2019 software. Please take a look at article below that tells you which add-ins are available at this time:
Please keep an eye on this article for future updates.
Tino Freitas
Technical Support Specialist
AutodeskBuilding/playlists | Contact Autodesk Support
Thanks for the response, however the pre-cast extensions don't provide the desired solution I was hoping for. Autodesk has stated that they don't have a release date or alternative at the present time.
I would look at this - your not getting 2019 extensions!!
http://blogs.autodesk.com/revit/2018/09/19/updates-to-revit-extensions-for-timber-and-rebar/
Thanks for the follow up. I'll miss the previous extensions but am always willing to move forward with new add-ins.
The article doesn't mention the Grids Generator Tool which is part of the Extensions tool.
I love the Grid / level / Element generator I use it a lot.
Do we know what will happen to this feature?
Timber and Rebar may not work but I have tested it and if you would like to get the other functions from REX2018 to 2019
you can install the REX 2018 first and copy this three addins file show in the picture from this location "C:\ProgramData\Autodesk\Revit\Addins\2018" to C:\ProgramData\Autodesk\Revit\Addins\2019
Kindly share with me the download link file for these extensions revit 2019
