Revit Crashes on closing project
peter7U4SR
Message 1 of 36
peter7U4SR
A number of us in the office are now encountering Revit 2017 crash every time a project is closed.
"Autodesk Revit has stopped working"
not specific to a particular project or build (2017.2 and 2017.2.1)
happens both on PC and bootcamp.
if any one knows a fix that would be great.
thanks,
Pete
Replies (35)
Message 21 of 36
This mutant add-in is still getting people two years, Revit versions, later. Will it ever be addressed?
https://forums.autodesk.com/t5/revit-structure-forum/revit-2019-crashing-when-i-close-a-second-proje...
Message 22 of 36
IMCornish
With Revit 2020 on the horizon what is the betting?  Mutant is the correct terminology, a rubbish add in even when you can use it.
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Message 23 of 36
kpatel2QWBH
Great! It really worked for me in Revit 2019 too. Thanks a lot.
Message 24 of 36
zcgt21
Sorry, but i'am only write in spanish.
Una solución que he encontrado es desinstalar Site Designer Add-In, con eso se soluciona el problema de "Crash" cuándo cierra un proyecto.
Message 25 of 36
Radish_G
Yes, I experienced the same issue.
Regards
Radish G
Message 26 of 36
Leads me to wonder why the Revit team allow this official add-in to be issued when it causes known problems. It's not like it is a third party thing
Message 27 of 36
 Site Designer addin for me too, lost a few hour over this.
Message 28 of 36
stosto6666
Is it Revit 2019 or Revit 2020?
Message 29 of 36
Revit 2020, it's bad because in use Civil 3D for my Topo.
Message 30 of 36
IMCornish
Both in my experience.
Andrew Robertson
Chartered Architect
Truro. UK
Message 31 of 36
I had the same problem. It was solved with removing the addins. Thanks.
Message 32 of 36
You can just disable the app by finding it in "C:\ProgramData\Autodesk\Revit\Addins\"  and move it out of the folder.
Then if you need it temporary move it back in. Not Ideal, hope this is fix in the 2021 version.
Message 33 of 36
kpatel2QWBH
I had the same problem. But it is now solved by just moving the addins to a temporary folder.
Hope, this might work for you a well.
Message 34 of 36
IMCornish
Once again I have had the problem start again yesterday but it continued after updating to 2020.2.1 so I have moved my 'Addins' folder and it now works.  Autodesk have had 2 years to resolve this issue!
Andrew Robertson
Chartered Architect
Truro. UK
Message 35 of 36
I started having the problem this past week, and after going through my addins the culprit was Site Designer.
Message 36 of 36
afshin.bariMP9G6
Just noticed this myself this morning, after many months of care free revit project close downs... Didn't noticed any Revit updates to reinstate the Site Designer.
