Revit and Autocad Xref's
BSchwartzkopf
BSchwartzkopf
Is there a way to link or attach an Autocad file that has overlayed xref's in it and not get the xref's to show in Revit? Right now we have to unload the xref's everytime we save our dwg's so that Revit users do not see items they do not care about. I would hope Revit has a way to deal with overlayed xref's that AutoCad does.
Replies (10)
J450NP13
Bind the xrefs
BSchwartzkopf
No I dont want to see the xref's I want Revit to not displaye the drawings that are xref'd into a dwg. Just like AutoCad will not display the drawings if I xref a drawing into another new drawing it drops the xref's out and only shows the current drawings data.
For instance:
I am drawing in A.dwg and I have 1.dwg xref'd in to A.dwg. If I choose to create a new B.dwg and xref A.dwg into it I would not see 1.dwg anymore because it is a child xref. This is all based on the parent child relationships in Autocad.
But if I start a ZZ.rvt file and I link or attach A.dwg into it I currently see A.dwg and 1.dwg. I do not want to see 1.dwg and I dont want to have to unload each time I save in Autocad to get this to work in Revit
J450NP13
Then save the file with another name and detach the xrefs.
BSchwartzkopf
How is your solution any different than what I am already doing? If you dont have a productive answer please dont reply. I am looking for a REVIT solution not an Autocad solution. I know how to handle Autocad what I dont know is REVIT.
I want a solution in REVIT to handle the xref's the way Autocad does and not display overlayed xref's of child drawings.
J450NP13
There isn't a solution as far as I know....its a totally different animal. Unless you create something in the API to dump all xrefs.  But other than that I doubt you will be able to do it out of the box.
kathryn.langan
What version of Revit are you working in? I was trying to reproduce this and when I have an xref as an overlay in AutoCAD, and I import/link the host DWG the overlay is not displaying in Revit. Do you have a sample fileset where this isn't the case?
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
sureshchotrani
You can swicth the layers off the X-ref in Revit, go to visibility & graphics(hit keys VV) go to import tab, expand the layers.
There you will see the layers X-ref is having layer name starting name of the X-ref file.
Hope this helps:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
kathryn.langan
I just wanted to check back in to see if you had a sample fileset, or whether the suggestion above of turning off the layer helped. Let us know if there's anything else we can do!
Katie Langan
Autodesk, Inc.
BSchwartzkopf
I haven't had a chance to test it out yet but I think the above post will work it's the best solution so far.
BIMologist_
I know this is a 8+year old thread, but I wanted to share the news!
AutoCAD links with XREF set to overlay appear in Revit (autodesk.com)
Finally
Status:
This incident has been resolved in:
Revit 2025  FINALLY!!!
Workaround:
Turn off layers in visibility graphics.
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
