Does anyone know if there is some IFC exporter bugs in the latest release of Revit 2023? Latest hot-fix didn't fix these issues described below either.
So I have an issue with exported wall geometry when exporting IFC to IFC 2x3. When exported to IFC4 format, geometry looks as it should in IFC. I have a wall with three structural layers, 70 mm concrete, 220 mm insulation and 150 mm concrete so the overall thickness of the wall is 440 mm. Wall type properties is modified to have a top distance extension parameter on 150 mm concrete layer.
In IFC 2x3 format Revit exports these walls like as "total wall top offset from level" would be set and not just one layer, which is given the "top extension distance" value. In IFC4 wall exports and displays as it should. Screenshots of the both IFCs are attached below. My earlier project was designed with Revit 2022 and about everything worked also with IFC 2x3. First one is from IFC 2x3.
The second issue what I noticed with IFC 2x3 (with Revit 2023) is that the other wall type is exported 20 mm thinner as it should. This wall type in question has a reveal profile of 20 mm of width loaded to it's structure. And as said, also this kind of reveals exported as they should when exporting to IFC 2x3 from Revit 2022.
Thanks in advance!
