REVIT 2024 Graphics Generation too Slow, Too Much Time to Open Views, Select Elements, Sych.
ahmed_fuqaha
Message 1 of 9
ahmed_fuqaha
I Would Ask About Revit 2024.1 Version, This Version Has a Lot of Issues with Opening Views, Moving Between Views, Select Elements and Open Imported Links (Dwgs), Also with Synchronizing Take a Lot of Time, Which Focused On (Graphics Generation Process).
Is There Any Suggestions for These Issues.
Replies (8)
Message 2 of 9
jay_colcombe
Apart from ensuring you have all Revit 2024 updates installed and ensuring your graphics card drivers are up to date I’m not sure what else is available?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
What are your computer specs?  I just upgraded our project from 2022 to 2024 and everything runs much more smoothly under 2024.
Message 4 of 9
ahmed_fuqaha
My Workstation spec. is too high.
Like the attached pic.
This issue happened for all team that work on Revit 2024.
Any suggestions?
@jay_colcombe @ToanDN
Thanks.
Message 5 of 9
jay_colcombe
If it is happening to all machines and the spec meets Revit recommended specifications apart from switching hardware acceleration on/off to see if makes a difference I can only suggest a full uninstall and reinstall on One machine firs to see if the problem arises from a bad installation.
Try a different installation method such a browser download and see if this makes any differences?
Here are the latest Autodesk Knowledge Base Article on such issues
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Slow-model-perform...
Jay Colcombe
Message 6 of 9
Ignus.E
That Processor by the looks of it was released in 2017. So probably 5 to 6 years old already. Might not be the determining factor but could contribute
Message 7 of 9
ahmed_fuqaha
Hi Ignus,
I guess, but one of our workstations has a 12th generation processor and still same issue.
Message 8 of 9
ahmed_fuqaha
Hi jay,
I saw this article, and we try the solution that mentioned, it works a lil, but still the main issue is there.
Message 9 of 9
What is your video card?
