All,
Has anyone else encountered an issue where modeling several hundred elements on a level cause the hidden lines to not show correctly? This happens on wood framed projects where any sizeable project can have hundreds of beam elements on each floor.
Two screenshots attached show less than 250 beam elements showing hidden lines correctly and more than 250 beam elements where the hidden lines do not show correctly.
With more than 250 elements, the hidden lines are not being drawn correctly. Each time a beam system or girder is moved, the hidden lines will "redraw" but incorrectly with many either not visible or showing solid lines.
When printing, the document will print ALL hidden lines correctly. Only the visibility on the screen is incorrect.
This appears to be a software issue.
We have seen this happen on all office computers with various specifications.
All have Nvidia Quadro P2000 video cards or better and 16GB RAM or better.
Does anyone know if this is a known issue and planned to be resolved?
Thanks!
-Eric
