Revit 2023 - linework not showing correctly.
mortizT3EZx
mortizT3EZx
We noticed a few new R23 large projects are having the same issue. Linework (specifically, dashed lines) projects sporadically correct. At times portions of the screen look correct, then I zoom out and all of a sudden, they're incorrect.
View Range is correct and has not been changed.
To verify this, I do a print preview or print, and all line work shows correct, it is only while actively working.
Examples below.
jay_colcombe
There is a knowledge base article about this bug:
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Inconsis...
There has been an update in 2023 that includes references to hidden linework and may resolve the issue at hand!
https://help.autodesk.com/view/RVT/2023/ENU/?guid=RevitReleaseNotes_2023updates_2023_1_2_html
Do note: There is no need to use the linework tool as this only is an issue when viewing the structural plans in revit and not with printouts
Jay Colcombe
Autodesk Certified Instructor
mortizT3EZx
Thank you, I will try the update.
