Rebar Cut Pattern Not Changable
BigPicture045
BigPicture045
I cannot change the rebar cut pattern. I need to change the color to a grey. I have tried to adjust the material, Visibility Graphics, Override VG, etc. with not success. I am trying to change the larger vertical rebars.
jay_colcombe
Rebar does not have a fill pattern representation like other Revit element so trying to add an overriding solid fill pattern and colour wont work in this instance
You can edit the Object Style but this will update all rebar in the model.
Have a look at this link for guidance on Filters
Ten Tips for Effective Rebar Detailing in Revit | by Autodesk University | Autodesk University | Med...
Jay Colcombe
Autodesk Certified Instructor
BigPicture045
Thank you for that resource. The answer is the change the "cut lines" parameter.
jay_colcombe
Apologies I presumed that knowing it was not a Fill/Pattern issue you would use Cut Lines, however I should have added it too.
Glad it’s all sorted.
Jay Colcombe
