Revit 2023 - Cannot see concrete outlines in sections views
Sharon.Abey
Observer Observer
Sharon.Abey
Observer
Observer
Hi All,
I have made a concrete column. I can see the concrete lines in the elevation view but unable to see it in the cross-sections created. The concrete is not hidden in elements or category for sure. I have checked that already. The problem is with the exiting sections taken (see attached file). I am able to see concrete line when I create a new section.
hmunsell
What do you mean by "Concrete Lines"? are you reefing to the Material, Outlines...? all the views i looked at in your file looked OK. can you provide a couple screen captures showing what your referring to?
Howard Munsell
Sharon.Abey
Observer
Observer
@hmunsell
The element that I have modelled is a concrete column (Yes you can call it a material type). The issue is I am not able to see its outline in the cross sections (or section views) that I have taken. Please see attached screen shots -  1 ) From the file that I shared- with missing concrete outlines in the cross sections. 2) From a different file, just to show how the cross section should ideally look like.
Increase Far Clip offset.
Sharon.Abey
Observer
Observer
Thanks. That worked.
