The advance steel plugin is not working with the latest windows update. Error message "The operating system is not presently configured to run this application"
I am running Revit version 2021.1 (all up to date) Windows 10 Pro version 1903 on a bootcamped macbook pro also all up to date.
In order to investigate this I need to know the version of Advance Steel Extension for Revit 2021 that you have installed on the machine. Can you send me a picture of the About dialog?
Hi @jasonEES8F ,
The issue that you are reproducing is also mentioned in this thread that was solved with a solution:
Please follow the steps from this article:
Kudos to @DarrenP
i actually got the link from this thread: https://forums.autodesk.com/t5/advance-steel-forum/quot-operating-system-quot-error/td-p/9754457
kudos to @IR8ASU1 for finding it
DarrenP
