Dear of Autodesk
I have an educational license as a professor and I downloaded Revit 2020 on a computer with Windows 8.1. Installation stop because I've Windows 8.
I look in "System requirements" and says that Revit 2020 products work on Windows 10 but can work with Windows 7 as a minimum requirement.
What happens with Windows 8? Is impossible to use Revit 2020 without Windows 10?
Thank you or your answer.
Solved by ennujozlagam. Go to Solution.
You can check below is not supported the windows 8
hello, i'm not the OP here. thanks
I just learned that I have to upgrade my OS to even install Revit 2020. It's bad enough that I have to maintain multiple versions of the software because of your incredibly user-unfriendly lack of version-to-version compatibility.
What is the reason for not supporting Windows 8? Hope it's a good one...though I'm hardly surprised. Thanks for nothing AutoDesk, I truly resent that I need your products.
You can install Revit 2020 on Windows 8 and Windows 8.1. Can only be installed via Autodesk desktop app, there is no silly protection in this installation for 2020.
hi,
are you find a solution for this problem ?
@Anonymous wrote:I just learned that I have to upgrade my OS to even install Revit 2020. It's bad enough that I have to maintain multiple versions of the software because of your incredibly user-unfriendly lack of version-to-version compatibility.
No problem. 🙂
(It's good to have revit 2019 installed for this installation for 2020 from Autodesk desktop app)
You can bypass this by using "# CB_FUNC=CustomCallbackRevitOSVersionCheck" in the setup.ini.
But what will it break when using this?
Could you educate me on how does this one works? I badly need it for my school project. Thank you in advance.
