Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit 2020 and Windows 8
13 REPLIES 13
Message 1 of 14
joseAgullo
14869 Views, 13 Replies
Dear of Autodesk
I have an educational license as a professor and I downloaded Revit 2020 on a computer with Windows 8.1. Installation stop because I've Windows 8.
I look in "System requirements" and says that Revit 2020 products work on Windows 10 but can work with Windows 7 as a minimum requirement.
What happens with Windows 8? Is impossible to use Revit 2020 without Windows 10?
Thank you or your answer.
Tags (2)
13 REPLIES 13
Message 2 of 14
ennujozlagam
in reply to: joseAgullo
You can check below is not supported the windows 8
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/G...
Message 3 of 14
Support for Windows 8/8.1 was dropped in Revit 2020, leaving only Windows 10 (version 1607 or newer) and Windows 7 as supported operating systems.  Here is a link to the system requirements for Revit 2020.
Tony Michniewicz
Revit Software QA Analyst
Message 4 of 14
hello, i'm not the OP here. thanks
Message 5 of 14
in reply to: Tony_Michniewicz
I just learned that I have to upgrade my OS to even install Revit 2020.  It's bad enough that I have to maintain multiple versions of the software because of your incredibly user-unfriendly lack of version-to-version compatibility.
What is the reason for not supporting Windows 8? Hope it's a good one...though I'm hardly surprised.  Thanks for nothing AutoDesk, I truly resent that I need your products.
Message 6 of 14
talk to microsoft about that
they ended windows 8 support back in 2016 nothing to do with autodesk
Message 7 of 14
graitechajek
You can install Revit 2020 on Windows 8 and Windows 8.1. Can only be installed via Autodesk desktop app, there is no silly protection in this installation for 2020.
Message 8 of 14
ArchASM
hi,
are you find a solution for this problem ?
Message 9 of 14
in reply to: ArchASM
what problem?
Windows 8/8.1 is not a supported OS for 2020 that is why there are system requirements
Message 10 of 14
graitechajek
No problem. 🙂
(It's good to have revit 2019 installed for this installation for 2020 from Autodesk desktop app)
Message 11 of 14
You can bypass this by using "# CB_FUNC=CustomCallbackRevitOSVersionCheck" in the setup.ini.
But what will it break when using this?
Tags (2)
Message 12 of 14
in reply to: graitechajek
Could you educate me on how does this one works? I badly need it for my school project. Thank you in advance.
Message 13 of 14
pendean
Message 14 of 14
in reply to: pendean
I will try that. Thank you so much. I will let you know if it works!
