Revision clouds' color
francfiles
francfiles
so we model in colour but we print in black but is there a way to have the just revision clouds print in colour? (see images below)
ArmanMargaryan
I do not think so, because it was necessary to print the logo in color. I did not find a solution
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
francfiles
You can easily print title block logos in colour by setting your PDF to colour. lgogs will print in color even if your printer setup is set to black lines
Jamhmer_Oc
Hi @francfiles
It is a good challenge.
Create view template, create a View Filter with no Rules that applies to all object types. Add it to your Filter list and set an Override to colour everything Black. When you want a Coloured plot, then remove the override but leave the Filter in place.
If you already use filters remember that; Revit processes the Filters from the bottom of the list to the top; That is, the lower filter will protrude the upper filter.
Jamhmer Oc
ennujozlagam
maybe here object styles > annotation objects? thanks
ArmanMargaryan
Thanks for the support.
Arman Margaryan
Linkedin | Facebook
