Reinforcment in Blended Column
shefypattambi
shefypattambi
How can I add Main and Tie Rebar  in this kind of column ? The Column is attached with this post.
Luiscko
The first thing that you need to check in yor family that is the family properties like structural column, and  concrete, the second thing is that you need to have check the box on the properties de parameter structural, and finally if you don have the stirrup with the  form that you need, you can edit your rebar always you have a rigth sketch about that.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
