Reinforced conrete panels
ianmotabr
ianmotabr
Hi there,
I'm working with structural reinforced concrete walls and I'm thinking in make the detail procedure in Revit.
Anyone work in this way? I'm looking for the best way to work in Revit with that.
Thanks!
jay_colc
Really this should be modelled using the Wall Tool and Area Reinforcement or Fabric Reinforcement and then add additional Rebar as required you can then create details from this.
Alternatively, you could look at the Precast option if this meets your needs.
In reality you model exactly everything that is being built and make details from this there re loats of reference on this from Autodesk - On-demand Learning | Autodesk
Jay Colcombe
Autodesk Certified Instructor
