Rebars don't appear when exporting to FBX
Hello!
I successfully exported my project to .FBX file, but when I open it with 3ds Max I see that objects such as rebars have not been exported, and only the exterior contours/shapes have been. Does someone why is this happening?
Thank you very much in advance!
KotairaKeila
Hi Fernando.
When exporting a FBX, Revit will export only everything visible in the current 3D view.
Before exporting, select those rebars you need to export to 3DS MAX, and in Propeties Pallete, "Edit" the "View Visibility States" to "View unobscured" and "View as solid" in {3D} View.
After making them visible, export FBX in Revit. And then, in 3DS Max Import > Link FBX (only those marked as visible will be exported)
I hope I have helped you in some way
Yes, that was the problem, I forgot to make rebars visible in 3D view...
THANK YOU VERY MUCH!!!
123qwerfv
what would you do ? Would you modify rebars in 3dmax or what bend rebar or duplicate it in a path , if you do that can you return it to revit again ??
