Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar shape code 34 (BS8666)
2 REPLIES 2
Joe_Hughes
210 Views, 2 Replies
Two issues I'm trying to resolve with shape code 34:
1) Want to change the E dimensions. It's currently greyed out.
2) Want to change the angle of the B dimension from 45deg to approx 51deg, which is a function of B, D and F. I.E. trying to replicate the green alignment in the mark-up.
See mark-up / screenshot below.
Tags (2)
Labels (2)
2 REPLIES 2
Joe_Hughes
in reply to: Joe_Hughes
Also the F dimension in the rebar shape family is wrong to BS8666. Autodesk needs to correct this!
jay_colcombe
I looked at editing the Shape directly and it turned it into a Shape Code 35
As regards the Leg E, you can override hook Lengths
I can only suggest looking at some third Party Addins for Revit as they create their own Shape Codes families which may be more accurate I know CADS RC3D had their own.
Jay Colcombe
Autodesk Certified Instructor
Forma Design Contest
