Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Presentation in 3D view
1 REPLY 1
199 Views, 1 Reply
Is it possible to activate the presentation toolbar in 3D view to show all/middle/selected rebar in 3D view?
If this is not possible, is there a work around manipulating the 2D/3D views essentially tricking Revit into showing this?
Any other suggestions on how to present the standard rebar 2d detail in a 3d view so the view is not overcrowded?
1 REPLY 1
ArmanMargaryan
I think this is not possible at the moment, But you can post it as an idea and if you have enough votes, they might include it in a next update.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Forma Design Contest
Technology Administrators
