Rebar Number problems using Splice Rebar
info7ATXY
info7ATXY
After I used Splice Rebar in a set of rebar, I tried to do a Schedule with the Partitions, but, instead of having (as usual) a single Rebar Number for each set, it applied a Rebar Number for every single bar.
Actually it happened not for both of the spliced parts, but just for one of them.
Infinitely grateful to anyone who can help me.
Thanks in advance
Martina
jay_colc
Do you have any variable rebar? If so is the numbering setting correct?
Do you have you Schedule set for Itemize every instance?
Quick Check
Jay Colcombe
Autodesk Certified Instructor
info7ATXY
First of all, thank you so much for your quick reply.
Yes, the set is variable and I didn't Itemize every instance.
Usually, without using Splice Rebar, it gave a single Rebar Number even to a variable set
jay_colc
I can only assume with the limited information that the Schedule contains a Filter or Sorting setting which is populating the information as min still group but if i sort by length then the schedule shows all individual Variable Reber Lengths
jay_colcombe_0-1731083499548.pngjay_colcombe_1-1731083623894.pngjay_colcombe_2-1731083891350.png
Jay Colcombe
info7ATXY
That was the problem! thank you so much!
