Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar: Measure dimensions of acute angles to extent of bend radius and not vertex
4 REPLIES 4
scottjames121
604 Views, 4 Replies
When a bar has an acute bend, the bending dimension should go from the end of bar to the far end of the bending radius.  When i create a rebar family with an acute bend, the dimensions want to snap to the angle vertex, and not the radius of the bend, which varies based on the rebar diameter.  Is there a work-around for this problem so that my dimensions reflect the image below?
4 REPLIES 4
Hi @scottjames121
The segment lengths are measured as shown in the picture you attached.
The rebar shape family has dimensions to the vertex because those dimensions drive the reference lines that define the rebar shape.
If you measure tangent to the corner fillet, from the beginning of the bar segments, you will notice that the reported values are the same as the parameter values in the bar properties.
Here's a simple example
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Thank you for the clarification.   When I would place a shape driven bar, it would snap to the covers based on the location of the vertex, which led to my confusion.  The rebar dimensions measured out the way you described, so that gives me some relief.  Could this be something that Autodesk looks at addressing in a future update?  It would save us detailers some time.
Hi @scottjames121
I agree that this is a good example where the bar could behave better on placement.
The bar constraints are from the bar segments to parallel concrete faces, so adjustment in this situation is also tricky.
How frequently, would you say, you encounter this situation in your rebar modeling tasks?
How often do you model shapes with such acute angles?
What other examples have you encountered, where you would need the bar to constrain with a vertex (or fillet) to the concrete?
The most common situation where I've ran into this this is an issue is when a triangular or diamond shaped tie is needed in a column cage where the fillets need to align with the rebar cover. 
Forma Design Contest
Technology Administrators
