Rebar End Ticks
Rebar End Ticks
Rebar End Ticks
I have a Rebar view problem, showing overlapping bars in a 2D view inside a sheet: I see something that could help me called tick mark but I don´t know were the options is. I need as shown on the picture, to mark the end and beginning of overlapping bars, and indicate them with a small tick if someone can help me....
Alan.johnson1970
Hi
You could duplicate one of the hooks and set it at 45deg and then just add that hook and at both ends.
AJ
AJ.
lumoric
you can try making a "tick" detail item family and lock it to rebar end so if it moves it'll move with it.
ovidiu_paunescu
Unfortunately you can only do this manually by adding some detail lines or detail items.
I wouldn't recommend hooks, as these marks are only annotations and not actual bends of the bars.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
-FDC-
You have to do this manually but if you want it to be in one of the next releases please vote massively for my suggestion in the idea section.
https://forums.autodesk.com/t5/revit-ideas/bar-endings/idi-p/7764622
