Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar arrangement
2 REPLIES 2
thilina_d
101 Views, 2 Replies
Rebar arrangement
Even if I set the cover and everything correctly, why couldn’t these rebars be extended to the curved boundary?
2 REPLIES 2
suskumar
in reply to: thilina_d
Hi Thilina,
You have to use varying rebar set. Make a simple set then click varying rebar button on structural modify tab and then stretch the rebar set.
jay_colcombe
As @suskumar stated this would need Varying Rebar Sets, however you need to place 2 sets as it will only identify one varying edge.
Therefore create one side and then mirror it and use the Bottom Tick Box to remove las bar so they do not overlap
Jay Colcombe
Autodesk Certified Instructor
Forma Design Contest
Technology Administrators
