"connection creation failed" structural steel connections
laverdadozharalibres
Message 1 of 12
Hi! I hope someone could help me on this.
Im trying to make a baseplate connection between a column and a footing (image 1) whit the add-in structural steel connections.
My problema begins when i click on the connection button and select  the 2 parts  for the connection because after waiting severas seconds i can see any geometry or warnings (like on the image 2).
Then when i change the primary element for the connection by clicking on the little blue circle it show up for some seconds the geometry i need (image 3), but past few secondse it desapears and show a warning saying "connection creation failed" (imege 4).
Does someone got that problem?
PD. If i Use just the column for the connection it just not appear any geometry or warnings at all, but Still can use the button for "modify parameters"
Replies (11)
Message 2 of 12
Taweepong.S
Hi ,
Please give me for more information of this case ,
What's your column steel section ?
Regard ,
Taweepong S.
Message 3 of 12
I dont know if there is a more spescific name for it but appear in the revit interfaz as "baseplate"
Message 4 of 12
hayley85
I have the same problem.
After choosing the component, then clicking on Connection , I received the error warning connection creation failed.JPG
Please help !!
Message 5 of 12
Taweepong.S
Hi ,
Please check your structural framing again.
It must be use only Certifies family for create steel connection.
Please see in link below ,
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Regard,
Taweepong S.
Message 6 of 12
catalin_lang
In the first case, when the column is the main element for the connection, are you sure the connection is not "hiding" in the foundation block?
The base plate connection is created at the column edge, without taking into count the foundation position
I look forward to your response,
Regards
catalin.lang
Message 7 of 12
catalin_lang
Hi @hayley85
If you have Autodesk Steel Connections for Revit 2017, what family of columns and beams you use?
Are you using "certified" families?
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Structural connections can be placed only on new structural framing families.
Regards
catalin.lang
Message 8 of 12
Regards
Yes i tryed on an isolated column whit same results
Message 9 of 12
hayley85
Many thanks Taweepong and Catalin !
I was using "certified families " in US metric with those errors. Then I tried to switch to use the libery to European specific and seems like it's running now.
Cheers
Hayley.
Message 10 of 12
jason2500
Observer
Observer
How do you switch the library?
Message 11 of 12
catalin_lang
What do you mean be switching the library?
catalin.lang
Message 12 of 12
HEY SIR/ MAM
i have connect bolt connection with two different type of members what it is coming with warning as " The shapes for medium and fine detail levels of connected element are inconsistent " .so please suggest me what i have to do
