"connection creation failed" structural steel connections
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi! I hope someone could help me on this.
Im trying to make a baseplate connection between a column and a footing (image 1) whit the add-in structural steel connections.
My problema begins when i click on the connection button and select the 2 parts for the connection because after waiting severas seconds i can see any geometry or warnings (like on the image 2).
Then when i change the primary element for the connection by clicking on the little blue circle it show up for some seconds the geometry i need (image 3), but past few secondse it desapears and show a warning saying "connection creation failed" (imege 4).
Does someone got that problem?
PD. If i Use just the column for the connection it just not appear any geometry or warnings at all, but Still can use the button for "modify parameters"
