put rebar set in circular column
Hello.
I have problem which I can't solve.
How can I put rebar set in circular column?
If I create rebar set, I can only put them in straight.
Could I put them in arc, fitted with column face?
I referred this URL but there is no button on Japanese version.
There is only pulldown to select rebar shape.(I use Revit 2016 Japanse version. not RevitLT)
(https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/e9bb11d1-ccf0-470e-9727-ca...)
Thank you.
Alfredo_Medina
@Anonymous
I would put one bar first, using "rebar type 00", "perpendicular to cover", at the limit indicated by the cover, and I would do a circular array.
Alfredo, thank you for your help.
I didn't notice the button was function of "perpendicular to cover".
I hoped set it as a Rebar Set to edit constraints easily, but I try "perpendicular to cover" as Work Around.
Best Regards,
Ali.maher
that's not good because when you tag the bar it will count only 1 bar, it should be possible in Revit and not with array.
EdwinG
jacobusJBFYP
This works very well, thank you.
