Converting Tekla to Native Revit
sean.mcdaid1
sean.mcdaid1
Has anyone come across a tool to convert Tekla elements into native Revit?
RLY_15
https://support.tekla.com/article/export-into-autodesk-revit-format
There's a video on the website explaining the process, though I do notice it does not include any demonstration of the Revit client side of things. Have you tried this process, and what does it output for you?
jay_colcombe
There was an add in Tekla to convert to a Revit.rvt file but it works only for early versions of Revit as per the previous post.
However I would recommend using the Tekla to Revit Integrator as this allows more functionality and mapping of sections for newer versions of Revit
Tekla Structural Designer Integrator for Autodesk Revit 2025 | Tekla User Assistance
There is also a Beta Data Exchange addin which works between lots of platforms which Autodesk and Tekla are trailing but not 100% on the progress of this and it is only a Beta version at this time.
Data Exchange for Tekla Structures®, Early Access | ACC & BIM360 | Autodesk App Store
Jay Colcombe
Autodesk Certified Instructor
sean.mcdaid1
Thanks for your response, much appreciated. The issue is that we need a structural contractor to convert their Tekla models into Revit format for handover. However, the response we've received from the contractor is that this isn't possible. I've forwarded your information on, thanks again.
sean.mcdaid1
Thanks for your response, much appreciated. we will explore these options.
mari.shimode
Hi @sean.mcdaid1, did you find the information provided helpful? If so, please use Accept Solution so that others may find this in the future.
If you would like to receive more comments or ideas from the community, please let us know.
Mari Shimode
mari.shimode
Hi @sean.mcdaid1, since it seems you found those replies useful, I have marked them as an accepted solution so others who have the same question can refer to it.
If you have any other questions related to what you originally asked, please create a new topic with a link to this post included so the community can follow the conversation easily. Thank you.
Mari Shimode
