Proper way to model curved beam reinforcement?
currently im sketching the main reinforcement and arraying the stirrups...is there any faster or better way to do this?
dzanta
most will use the Radial array feature to array the reinforcing
some will try the Vary Rebar Set feature....works only some of the time
some will use Dynamo
http://aucache.autodesk.com/au2016/sessionsFiles/15357/11251/handout_15357_ES15357-VERMEULEN-AU2016....
https://www.youtube.com/watch?v=4LVp1ugNo_U
hope these help.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
eliptical beams?? we cant array that...
dzanta
oh my....elliptical arrays....they are the bane of architecture!...let me think about this one today...will get back to you.
dzanta
Perhaps create the stirrup rebar as an adaptive family and then use the Divided Path function to array it.
or
Create the stirrup rebar as a baluster family and then use this in a railing.  The placement/quantity of the "rebar" can then be adjusted using the Type Properties Window under "baluster placement"
