Project Browser not visible in Revit
CIVILPRAKASH3112
CIVILPRAKASH3112
Community Visitor
Community Visitor
Project browser in rivet in not visible, i had checked in user interface, view tab, etc.  and even i had uninstalled the software and again installed... even the project browser is visible.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Project Browser not visible in RIVET]
jay_colcombe
Here is the Autodesk Knowledgebase article on this topic and found usually it is related to Screen Resolution and setting to recommended can fix this.;
Project Browser or Properties window is missing in Revit
Jay Colcombe
Autodesk Certified Instructor
handjonathan
Hi @CIVILPRAKASH3112
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
