In the precast extension, how can you control the amount or horizontal distance between the automatic placing of the bracing in solid walls?
Solved by teodorb. Go to Solution.
Hi @gerstal82 ,
The rules for placing bracings are governed by the minimum distance to edge (from the lifter) and the minimum distance to the opening parameter. usually, the bracings are positioned in line with the lifters if there are no openings in the wall. After the generation of bracings you can manually move them to the desired location. The number of bushings is the same as the number of lifters.
Kind regards,
