2018.3 Revit: Complex insitu concrete slab
Hi All
I have modelled an exterior slab that has been designed by a Civil Engineer to provide drainage. I started with a 550mm thick slab with variable thickness, then by linking a civil dwg with contours, I used the shape editing tools to get the top surface to follow the contours. Now I need to add rebar to this slab, however the rebar does not follow the top of the edited slab. Is there another way to make this slab and have the rebar stay within the slab?
I have attached my model.
Trevor
KrisAribal
yeah you will have a hard time putting reinforcement to that "slab"
Why did you edit the floor again?
