Point boundary condition
is it Possible to add a point boundary condition to a wall element. Revit UI does not seem to allow this, if any one has any idea even throw the API, I would appreciate it.
cheers
Salim
catalin_lang
There is no possibility to do this...
But, I'm more interested about your case... when would you like to place a point support for a wall?
catalin.lang
its for concrete suspended facade elements.
see the following link.
https://forums.autodesk.com/t5/revit-structure-forum/point-support-on-wall-elements/td-p/9564831
rolfsmetveit
we use often piles under walls, and it would be more efficient if we could use point boundary under wall ends instead of line boundary type.
