Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Platform plate
1 REPLY 1
rimutaka
347 Views, 1 Reply
Platform plate
I create a platform plate but have an issue between end plate, secondary plate and stiffeners.
My questions:
1. How do I make the dimensions of end plate and secondary plate equal and with the same elevation?
2. How do I add stiffeners and adjust their elevations?
Attached are two screenshots to describe my above questions.
1 REPLY 1
catalin_lang
in reply to: rimutaka
1. You cannot. The formulas are not working in the connection's dialog.
2. You can add only the "middle" stiffener for this kind of connection. If need, and if you are using the 2019 version, you can create a custom connection from this Platform plate connections and manually add plates as stiffeners in this custom connection.
catalin.lang
Forma Design Contest
