Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Plate elements show up as transparant when exported to IFC
1 REPLY 1
robert.sandborg
123 Views, 1 Reply
I'm having issues when exporting my model to IFC in Revit 2020, with some of my steel plate elements showing up as transparant or completely missing.
Should add that the same exact plates that show up as transparant in some places, are fine in other.
Plate connected to beam is transpararent in IFC (red arrow). While other plates are good (blue arrow).
Same plate connected to column is just fine
I have tried many different Export setups, and the issue is not solved.
Any idea how to fix this?
Thanks in advance!
Regards
Robert
1 REPLY 1
did you check the IFC manual
https://damassets.autodesk.net/content/dam/autodesk/draftr/2528/180213_IFC_Handbuch.pdf
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Forma Design Contest
