Placing a new door in an existing wall generates unexpected dashed lines at the door opening if the phase filter is set to "Show All".
Changing the phase filter to "show previous + new" gives the desired result, i.e. no weird "phantom" lines.
Does anybody know why that happens?
Thomas
Solved by RDAOU. Go to Solution.
Solved by ToanDN. Go to Solution.
That is normal.. The dashed lines indicate the part of wall being demolished.
To build a door you need to knock out an opening ie: demolished
The behavior depends on the Overrides which are defined for each Phase Filter... if you do not want to see demolished simply got to Manage tab >> Phases >>> and in the overrides set it to not show
