Phasing & Door Opening show weird behavior
Thomas.S.Teichmann
Thomas.S.Teichmann
Placing a new door in an existing wall generates unexpected dashed lines at the door opening if the phase filter is set to "Show All".
Changing the phase filter to "show previous + new" gives the desired result, i.e. no weird "phantom" lines.
Does anybody know why that happens?
Thomas
That is normal.. The dashed lines indicate the part of wall being demolished.
RDAOU
@Thomas.S.Teichmann
To build a door you need to knock out an opening ie: demolished
The behavior depends on the Overrides which are defined for each Phase Filter... if you do not want to see demolished simply got to Manage tab >> Phases >>> and in the overrides set it to not show
