Path reinforcement - Adjusting U-Bar dimensions
Joe_Hughes
Message 1 of 9
Joe_Hughes
I'm trying to use the path reinforcement function to model rebar. Please see the attached screen-shot for reference.
How could I change the "B" dimension of the U-Bar (highlighted blue) to 105mm? I want the B" dimensions of the U-bars on the perpendicular faces to remain 125mm.
Help appreciated.
Joe
Replies (8)
Message 2 of 9
DavidDillonJr
@Joe_Hughes I believe, if I understand what you are trying to do. You will have to manual adjust the shape of rebar element. To modify a rebar sketch, Click Modify / structural rebar > Edit Rebar Sketch tab, Adjust the rebar sketch.
Otherwise you need to change the shape of the rebar.
David Dillon
Message 3 of 9
Ahmed_M_Heteba
you can use remove path system see screen shots
to avoid change for the other shapes make a duplicate to the shape from project browser families
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 4 of 9
Joe_Hughes
Much thanks @Ahmed_M_Heteba !
Useful tool!
Message 5 of 9
Joe_Hughes
@Ahmed_M_Heteba  a follow-up question if I may; I would like to use the Multi Rebar Annotation to call-up the rebar, however I can only select one set of bars. I fear this is because the foundation slab is at a gradient 1:40. Is there a solution for this?
See screen shots attached for reference.
Joe
Message 6 of 9
Ahmed_M_Heteba
Could you share the file if possible
Message 7 of 9
Joe_Hughes
@Ahmed_M_Hetebafile attached.
Thanks.
Message 8 of 9
Ahmed_M_Heteba
unfortunately i couldn't do it
Message 9 of 9
Joe_Hughes
@Ahmed_M_Hetebathanks for trying.
I may start a new post on the forum to ask the question.
