Assigning a radius parameter to an array
mframpton20
mframpton20
This is a bolt hole radial array for a plate I'm working on.
I've managed to program the diameter of the holes and can produce the qty of holes as a parameter.
Now I'm stuck on how to assign a radius parameter to the center of the array. Thoughts?
TIA
mframpton20
Found the solution. The secondary vertical dimension when activated can be flipped into a parameter you have created.
