Parameter and visibility issue
hudza.xitgbb22
hudza.xitgbb22
this error happened : None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
it when i try to add isolated in structure
here the video : https://youtu.be/ZuxoNRE-o3Y
how to fix visibility error ? it almost happened that when i try to add any family
ArmanMargaryan
Please watch the attached video.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Jamhmer_Oc
Hi @hudza.xitgbb22
As shown by the farmer, change the range of vision to be able to see it.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Jamhmer Oc
