Setting up structural plan views
leahmbell
leahmbell
I have been working in Revit for a long time, but I have recently started to draw our structural plans in Revit too but I need some help. I haven't found a way to accomplish what I am after in a single plan. I am having to create an underlay plan and stack the 2 views over each other on the sheet to achieve what I am after, and it still doesn't look quite right.
-I would like to show the roof or floor diaphragm with a solid hatch
-I want the walls above the floor/roof diaphragm to show dashed.
-I would like the walls below the floor roof diaphragm to show solid with a hatch pattern.
I have adjusted the view depth and gone round and round with the VG and it doesn't work.
Could someone tell me if this is possible and how to go about achieving this in a single plan? Thank you so much for any help.
Mohammed_Ata
IT is according to your view direction and view range. You can change and set the surface and cut patterns from VGs
You can do it.
Mohammed Ata
Structural Design Engineer
Autodesk Expert Elite
semi
change the visibility settings of floors and roofs in the view template or view graphics override
Assuming you are looking to the ceiling in a structural plan view you first set plan discipline to Structural and show hidden lines by discipline
Then make sure you can see your floor (with a hatch in your case) so this floor blocks the view from the walls above.
You need something to block an object or geometry to make it appear dashed.
Next you check your view range and make sure your top and view depth are covering about 10 to 20 cm above the floor level, so your view depth is actually cutting the walls above.
you can do this with multiple solutions:
1) as with your floor make a cut pattern with your walls:
If you want to specify a certain wall type you can make a filter.
Same principle as above but you can specify your wall type or wall discipline:
